Letto consigliato per 4 persone
Zinus Curtis Upholstered Platform Bed Frame Review
Zinus is a reputable known to manufacture quality and affordable furniture. The company has been in the business of manufacturing furniture for many years. Therefore, nothing should make you doubt the quality of the Zinus Curtis Upholstered platform bed.
No better relief comes with lying on a comfortable, cozy bed after a long tiring day. Zinus manufacturing company is known to come up with attractive and affordable platform beds. Here, we are looking at Curtis Upholstered platform bed.
The bed is designed explicitly with attractive upholstery support to give it a soft touch. The bed is a perfect blend of comfort and contemporary trend. If you are looking for furniture that will add a modern touch to your bedroom, this is the bed frame for you. The bed frame comes in different sizes, and it is you to choose your most preferable size.
Check This Out:
Platform queen bed
Important Features
The platform bed is a bed of steel, which gives it a strong foundation. If you are worried about coming into contact with iron, you have nothing to worry about. The bed is perfectly fitted with beautiful upholstery that conceals the steel components of the bed. The first thing you see is the impressive tailoring used to put the bed together.
Its fabrics tug tightly around the frame, which makes the bed look sleek and generally impressive. The fabric tugs fit tightly all-round the frame. If you have white walls in your bedroom, the grey color of this bed perfectly offsets it. Furthermore, grey is a color that goes well with many decors.
Comfortability
The primary purpose of a bed is to offer rest after a long day. Therefore, when buying a bed frame, the first thing to consider is its comfortability. No matter how beautiful the bed can be, if it is not comfortable enough, it loses its purpose.
The manufacturer has put non-slip tape on several slats to prevent the mattress from falling. To reveal the adhesive in the slats, you just have to peel off the upper part. The feature will prevent you from repositioning your mattress after a few days of use.
If you are interested in the strength of its foundation, the bed frame doesn’t creak even during bedtime activities. If the platform bed starts making noise in the future, all you have to do is re-tighten the bolts, and the bed is ready.
Dimensions
is a perfect fit for people who have a problem getting in and out of bed. It is available in three sizes, queen, full and king size. Zinus has given you three choices to choose from. Here is the dimension of each of the three beds.
When choosing which one of the three types to take home, consider the size of the bedroom—number of sleepers, body weight, and probably your budget. King and Queen size mattress will probably cost more than the full-size bed.
If you are purchasing a mattress foundation for your master bedroom, a queen-size bed is most suitable. However, if you are purchasing a bed for the kid’s room, a full-size mattress foundation is most appropriate. Zinus has provided all these types to help the customer in selecting. That which you want is what you will get.
Zinus Curtis Upholstered Platform Bed Frame undoing
One thing many customers have complained about is the fact that the bed its plastic legs. Under pressure, its legs tend to scratch sensitive flows, mostly those made from hardwood. However, the solution to such a problem is simple, all you need to do is get pads, and your issues will be solved.
Storage
If you have a problem with storage in your bedroom, I will not advocate this type of bed for you. Unless you are looking to keep small items such as shoes, the under-bed space available in this bed is way too short.
The idea is that Zinus has various other types of beds you can choose from that has more under-bed storage space that you can store some of your items. Only short boxes and small pieces of cloth can fit it is under bed storage.
Height
If you are worried about the height, the bed makes it easy for you to move in and out of bed. Even if you put a box spring, the height of the bed will still not be too tall. If you are purchasing a mattress foundation for your child or a person with a particular health problem, this is the bed for you.
Pros
The platform bed is form padded; hence your mattress will not slip its place with ease. The feature also adds some bit of softness to the platform bed.
Modern design
One sure thing about this bed is that it would sure lift the look of your bedroom. Many people especially love its contemporary design. Once you place the bed frame on the bedroom, the look of your room changes completely.
Warranty
To assure its quality, Zinus has given a 5-year warranty for the bed. The quality of this product is without a doubt top-notch. You have a grass period of 5 years in case the period has an unspecified default.
Cons
Many customers have complained about the product not being strong and durable enough.
Conclusion
If you review this
queen platform bed from various customers, you will realize that the mattress foundation is an excellent choice to have in our bedroom. Everyone would love the bed being the focal point of the bed. Well, this is what the Zinus Curtis Upholstered Platform Bed Frame brings to your bedroom. It is furniture that will catch the eyes once you get into your bedroom. As for the comfortability, this type of bed gives what you would expect in a platform bed. Buy this Zinus bed today and get value for every coin you will spend on the bed frame.
Ultima modifica di bettycarter il 24/10/21 16:16, modificato 2 volte in totale.
Re: Letto consigliato per 4 persone
Stai mescolando più di una questione: le dimensioni del letto e la comodità dello stesso letto.
Per le dimensioni direi che potresti pensare a un letto con una buona rete di 180 cm di larghezza (rete a doghe, doppia campata).
La larghezza 2 metri è una misura non standard e potrebbe costare di più.
Per la comodità invece devi acquistare un buon materasso, ma senza sapere quanto pesi e quanto sei alta è impossibile suggerire qualcosa di adatto a te.
Sei incorreggibile. Sallo.
